14 years agoOut of memory error
following is the error i'm getting when i run fitter. "Out of memory in module quartus_fit (2147 megabytes used) while running 32-bit Quartus II 32-bit on a 64-bit OS platform. Please use the 64-...
14 years agoNo you will need a 64-bit OS if you want to use more than 3Gb of memory. What Stratix5 device are you targetting? The bigger the device the more RAM you need.
