14 years agoOut of memory error
following is the error i'm getting when i run fitter. "Out of memory in module quartus_fit (2147 megabytes used) while running 32-bit Quartus II 32-bit on a 64-bit OS platform. Please use the 64-...
14 years agoI am targetting it to a stratix 5 device., i have to meet around 220MHZ for the design., so wat is the minimum RAM space i need to have??
and if i can add more ram to the system then can i continue using the 32bit version??
