17 years ago
oscillatory circuit for LFXP6C-5TN144C
I'm developing a FPGA programmer using LFXP6C-5TN144C as core. I'm stuck with the designing of oscillatory circuit for the same. I'm stuck with the development of 24MHz circuit at 3.3v.
kindly inform me were could i get this type of crystal oscillator. I have checked onto many sites like fox electronics, electronics-manufacturers....etc.but haven't found the correct one.
i did goggled "crystal oscillator 24MHz" but got circuits generating this frequency. but the problem is that they generate this frequency with 5v, the think i need is of 3.3v...as my FPGA supports voltage range from 2.8v-3.3v
kindly post the reply as soon as possible, so that i can fasten my work.
pls, anyone who knows a solution for this problem kindly post ur views and suggestions....
thank you
varun v g
    hello,
    I'm heartly delivering thanks to all of you for helping me with your knowledge. I got an apt crystal oscillator much suitable for my application (a 4 pin SMD from CTS).
    thank you all
    thanks and regards
    varun
    Jauch VX3F is a part that runs at 3,3V ...
    realy there are at least a dozend manufature that can be second source to each other as replacement for the same footprint.
    You obviously didn't look hard enough. The second Digikey hit is a 3V part. Lots of 3.3V parts are also available.
    thank u for ur assistance....
    thanks and regards
    varun v g
    such a component is as common as a resistor, capacitor, connector, screws,...
    digikey, farnell and uncounted others have them on stock.
    there are so many manufatures out there ...
    have you googled for "crystal oscillator 24MHz" ???
    --- Quote Start ---
    A crystal oscillator is the usual solution. 24 MHz 3.3V oscillator is a standard product, available in different packages, e.g. DIL, SMD.
    --- Quote End ---
    hello,
    first of all thank you for your reply.
    kindly inform me were could i get this crystal oscillator. I have checked onto many sites like fox electronics, electronics-manufacturers....etc.but haven't found the correct one.
    thank you
    varun v g
