15 years agoOptimum way to do Count = Count + 1 Using only std_logic_1164
Hello I'm new in this forum and recently I received an assigment for my Digital Systems Class. Its common to use in C/C++ or any high level language, a notation like cont = cont + 1. But my professor...
15 years agoHello everyone, thanks for your replies.
As std_match mentioned I only used half adders modules. I tested my counter making a clk division and running on modelsim. The code is next library ieee; use ieee.std_logic_1164.all; entity clkdiv is port( sysclk : in std_logic; sysrst : in std_logic; clkdiv : out std_logic ); end entity; architecture arch of clkdiv is component halfAdder is port( ah : in std_logic; bh : in std_logic; sh : out std_logic; ch : out std_logic; ); end component; signal cnt : std_logic_vector(3 downto 0); signal cn1 : std_logic_vector(3 downto 0); signal carr : std_logic_vector(3 downto 1); signal tmp : std_logic; [/INDENT]begin h0: halfAdder port map(cnt(0), '1', cn1(0), carr(1)); h1: halfAdder port map(cnt(1), carr(1), cn1(1), carr(2)); h2: halfAdder port map(cnt(2), carr(2), cn1(2), carr(3)); cn1(3) <= cnt(3) xor carr(3); process(sysclk, sysrst) constant clow : std_logic_vector(3 downto 0) := x"7"; constant chigh : std_logic_vector(3 downto 0) := x"F"; begin if sysrst = '0' then cnt <= x"0"; elsif sysclk = '1' and sysclk'event then cnt <= cn1; if cnt < clow then tmp <= '0'; elsif cnt >= clow and cnt < chigh then tmp <= '1'; else cnt <= x"0"; end if; end if; clkdiv <= tmp; [/INDENT]end process; [/INDENT]end architecture; Maybe it can be improved, but at least I can make it fit in the CPLD since a reduction of ~16% than using the classic "variable <= variable + '1'; Thanks all you guys,
