17 years agoOfmd modulator: IFFT
Hi All.
I am realizing an Ofmd modulator. I have a problem with zero padding of the IFFT. :confused: I decide to use the FFT MegaCore Function v9.0. I have 1536 samples and I choose a 2048 samples IFFT. Now, how I have to do zero padding? I think it depends from 1) the input data mode that I choose in FFT MegaCore (natural, bit reversed, DC centred) 2) my samples order. They are DC-centered because they corresponding to carriers from (-768 to 768) excluding 0, that is DC carrier. In that case where have I to put zeros? Moreover from FFT MegaCore User Guide: what does it mean that the signal is in "natural order", "bit-reversed" or "DC centred? And if I pass to the IFFT Ip core a signal DC-centred and the output is in natural order, have I to re-order samples in DC-centred order before transmission? I hope someone can explain me, sorry if I was a bit confusing.3 Replies
Hello Dear, please i need the core of ofdm modulator if you can send it to me : [email protected]
Thank you hawke. I don't undestand two things. 1) Why have I to put a zero in front of my vector? 2) And why "Scale factor should be considered"? Thank you again.
To keep the shape of the spectrum, u should pad ONE zero to the front to keep DC centred, and 2048-1536-1 zeros to the center of the 1536 samples.
Scale factor should be considered.
