Steve-Mowbray-ENL's avatar
Steve-Mowbray-ENL
2 years ago
Official quick method of switching between devices in device migration list
what is the official but quick method for switching between devices in the device migration list?
I do hope it doesn't involve creating a whole new project variant for each target device as this will (manually) duplicate any project level improvements between the project variants...
  • sstrell's avatar
    sstrell
    2 years ago
    That's your call then. I thought the only thing you wanted was to quickly switch devices and I/O assignments, but if there are other things that may change and need to match between the different revisions, then it might not be the best way to go.
    You could instead use Tcl scripting in the .qsf for this type of stuff.
  • FakhrulA_altera's avatar
    FakhrulA_altera
    Hi Steve-Mowbray-ENL,
    Thanks for your clarification. I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions. Thanks.
    FakhrulA_altera
    Do you have any further questions on this matter? Else, I'll move this to community support, making it a helpful reference for others in the forum.
    Fakhrul
  • sstrell's avatar
    sstrell
    I'm presuming you are talking about the feature of adding migration devices in the Pin Planner to make sure pin assignments are valid across the multiple devices.
    Probably the best way to implement this would be to use the revisions feature in Quartus. Create a new revision of your project based off the current project and then switch the device in the new revision. You can always switch back to the original revision.
    I'm not sure if you'll lose the I/O assignments when you change the device, but before doing so, you can export the I/O assignments from the Pin Planner and then import them back in after changing the device (kind of like a backup).
    • Steve-Mowbray-ENL's avatar
      Steve-Mowbray-ENL
      Hi sstrell
      I am specifically hoping to avoid creating a project variant -- how about manual edit the QSF file:
      ### pick active device
      #set_global_assignment -name DEVICE 10AX027H4F34E3SG
      #set_global_assignment -name DEVICE 10AX032H4F34E3SG
      #set_global_assignment -name DEVICE 10AX048H4F34E3SG
      set_global_assignment -name DEVICE 10AX066H4F34E3SG
      set_global_assignment -name DEVICE_MIGRATION_LIST "10AX066H4F34E3SG,10AX057H4F34E3SG,10AX048H4F34E3SG,10AX032H4F34E3SG,10AX027H4F34E3SG"
      Steve
      • sstrell's avatar
        sstrell
        I'm not sure what you mean by a project variant. The revisions feature is still a single project (single .qpf file) with multiple settings files (.qsf files). When you switch revisions (pop-up list in toolbar or Revisions dialog box), you're just switching between the .qsf files so you don't have to go in and edit them manually like this.
