16 years ago
Odd Bug
Hello, I am very new to Altera and microchip programming. Today I wrote(with a lot of code borrowed from a book) a program that does what it's supposed to do, but also something else that it's not.
Here's the program:
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY Clockdiv IS PORT (
Clk25Mhz: IN STD_LOGIC;
Clk, Clk2: OUT STD_LOGIC;
PinNumber: OUT STD_LOGIC_VECTOR(2 DOWNTO 0));
END Clockdiv;
ARCHITECTURE Behavior OF Clockdiv IS
CONSTANT max: INTEGER := 25000000;
CONSTANT half: INTEGER := max/2;
SIGNAL count: INTEGER RANGE 0 TO max;
SIGNAL pin: INTEGER RANGE 0 TO 7;
SIGNAL state: STD_LOGIC;
BEGIN
PROCESS(Clk25Mhz)
BEGIN
IF Clk25Mhz'EVENT and Clk25Mhz = '1' THEN
IF count < max THEN
count <= count + 1;
ELSE
count <= 0;
END IF;
IF count = half THEN
IF pin < 8 THEN
pin <= pin + 1;
ELSE
pin <= 0;
END IF;
END IF;
IF pin = 7 THEN
Clk <= '1';
Clk2 <= '0';
ELSE
Clk <= '0';
Clk2 <= '1';
END IF;
CASE pin IS
WHEN 0 =>
PinNumber <= "000";
WHEN 1 =>
PinNumber <= "001";
WHEN 2 =>
PinNumber <= "010";
WHEN 3 =>
PinNumber <= "011";
WHEN 4 =>
PinNumber <= "100";
WHEN 5 =>
PinNumber <= "101";
WHEN 6 =>
PinNumber <= "110";
WHEN OTHERS =>
PinNumber <= "111";
END CASE;
END IF;
END PROCESS;
END Behavior;
It's supposed to flash the leds, in a pattern that will show binary numbers from 0 to 111 increasingly and then start over and just keep doing that. Which it does very well, but it also changes two segments on bcd display every time all the 3 led lights are on. The pin assigments are for the three rightmost green lights on the desk assigned to the vector and one input for 50mhz clock. I know there are unused outputs and signals in the program, I left it as it is in case something causes the error. I've tried it with the red leds and it produced the same problem, except with a different segment of the bcd number. Didn't have more time to experiment with unfortunately.
The altera desk is EP2C35F672C6. I don't know if someone will be able to recreate the problem, but at least someone can tell me if it's a bug in the desk/software or a fault in my program.
Keep on truckin'
    Cris72: Yes, it's a mistake, the pin is supposed to go up to 7 then drop back to 0.
    FvM: I'll get rid of the unused pins next time I have access to the board and see if it solves the problem. I had assumed that unused pins went unused.
    Check the actual pin assignment in the compilation report! I guess, you mean with "unused outputs" that you didn't assign pin locations for these pins. Quartus will assign arbitrary pins for it, possibly causing unwanted effects in your circuit.
    Your code doesn't control the segment display directly, so I can't tell you what's the problem.
    However I see that 'pin' changes from 0 to 8: is this correct? Or maybe you were supposed to use a 0 to 7 range?
    Infact in the following case statement you only account for these 8 values.
    With the code you have written PinNumber keeps the "111" status twice.
