10 years agoOCT Termination - how many pins?
Hello I want to use 50 ohm oct termination with calibration on an Cyclone IV E device (EP4CE55F23C7). In the QSF file i define the termination for a 8bit bus RAM0_DQA: set_instance_assi...
10 years ago --- Quote Start --- Hello With more pins I get the following Error: Error (176210): Can't place pin RAM2_DQB[1] with I/O standard 2.5 V, Termination setting Off, and PCI I/O setting on due to device constraints --- Quote End --- Hi Robert, are pin on supported side/bank? From user manual cyiv-51006.pdf you can find here https://www.altera.com/products/fpga/cyclone-series/cyclone-iv/features.html bottom of page right column "connectivity" line I/O Features (pdf) at page 8 we read: cyclone iv devices support r s oct with calibration in the top, bottom, and right i/o
banks. the r s oct calibration circuit compares the total impedance of the i/o buffer
to the external 25 ohm ±1% or 50 ohm ±1% resistors connected to the rup and rdn pins, and
dynamically adjusts the i/o buffer impedance until they match (as shown in
figure 6–2).
--- Quote Start --- Error (176210): Can't place pin RAM2_DQB[1] with I/O standard 2.5 V, Termination setting Off, and PCI I/O setting on due to device constraints What´s the reason for that? If I assign no oct termination, the design dose fit. How many pins can use the oct feature? --- Quote End --- http://quartushelp.altera.com/14.0/mergedprojects/msgs/msgs.htm insert your error number, the error appear under the search pane then click on it and read the help about constraint. Or faster from quartus click on error to go to this help page. If this doesn't help please post pin assignment. Best regards
