Uri_Schachar
1 year agooc-3/oc-12 mapper framer
Do you know if there is an IP for oc-3/oc-12 mapper framer?
Harshx
1 year agoHi,
Thanks for contacting Intel. I'm assigned to support request.
Kindly check for various IPs for your related speed in Intel FPGA transceivers. e.g. JESD204B/C or PMA and FEC Direct PHY IP. You also need to check for what type of transceiver (H-tile, F-tile etc ) you are going to use as per your required speed range.
Harsh M
