14 years agoobject assigned a value but never read - does this effect synthesis?
Hello, I have the following small module which is intended to store the value 0xFF in a register when a button is pressed.
module connector_test(button, txd);
input button;
output reg t...
14 years agoYou're suggesting that perhaps since no other resources are being occupied (other than the fan-out-less register I'm trying to keep) that the compiler may ignore the synthesis attributes?
Have you seen such behavior before? -k
