14 years agoobject assigned a value but never read - does this effect synthesis?
Hello, I have the following small module which is intended to store the value 0xFF in a register when a button is pressed.
module connector_test(button, txd);
input button;
output reg t...
14 years agoWith zero resource things may not be predictable.
Your design indeed is implemented as just wiring input button to output txd directly. I suggest you try a bit more logic to keep compiler happy.
