13 years agonot able to ping fragmented data
hi, In our project we are using one device with Triple Speed Ethernet IP (10/100/1000 ethernet MAC with 1000base-x/SGMII PCS) at the source side and using another device with Triple Seed Ethern...
13 years agothe same test i made in the two Linux PCs with ping data size of 65500, the ping was happened fine, only problem i facing in the windows PCs.
This also i tested one side windows and other side Linux PC at that tiem also Ping with a data size of 65500 happened fine. is there any PC setting issue or any configuration i need to made. Thanks, Santhosh
