10 years agoNo ROM initialization (FIR, NCO coeffecients, etc.) on MAX10 SCE Compact Devices?
Hi, The max 10 configuration user guide (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/max-10/ug_m10_config.pdf) states on page 2-2 that MAX 10 devices with "Com...
10 years agoI've had a play - having seen another, similar, forum thread. I can reproduce your issue. I've not used any of the 'compact' MAX 10 devices. Hence, have not appreciated the limitations.
Memory initialisation needs CFM2 - which the 10M02 doesn't have. Furthermore, the MAX 10 Device Overview, in the Device Feature Options section, covers the fact that 'Compact' devices don't support Memory Initialisation. So, unfortunately, the device you're targeting simply won't support what you want. However, as you've found the 'flash' (or 'analogue') variants will. I hope you can find a suitable alternative. Cheers, Alex
