13 years ago
Nios2eds can't detect usbblaster
My os: Ubuntu 12.04 lts
After I configured the .sof file for my de1 board, I tried to program the "hello_world_small" template to the board but i got
"no nios ii target connection paths were located. check connections and that a nios ii .sof is downloaded."
My SOPC design is the following:
https://www.alteraforum.com/forum/attachment.php?attachmentid=7528
Program "hello_world_small.c":
https://www.alteraforum.com/forum/attachment.php?attachmentid=7529
When i selected "run as Nios II Hardware", i received:
https://www.alteraforum.com/forum/attachment.php?attachmentid=7530
Please helps.....
Thanks!
    Hi.
    Delete the software and create it one more time. If it doesn't help regenerate nios2 system and recompile Quartus II project, then create your Hello world software. I face the same problem from time to time and don't know another way to solve it) Have a nice day.
    Thank for help
    I recompile software, hardware many times, but i get the same problem.
    I install "Altera Quartus Usb blaster" by creating /etc/udev/rules.d/51-usbblaster.rules:
    # Altera USB-Blaster rule to set mode to 666.
    SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6001", MODE="0666", NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}", RUN+="/bin/chmod 0666 %c"
    Can you check that FPGA is successfully configured? For example, leds start blinking or conversely stop blinking
    problem is resolved......
    i add "export QUARTUS_ROOTDIR=/opt/altera/12.0sp1/quartus" in .bashrc file
    thank you!
