15 years ago
<terminated>nios Nios II Hardware configuration[ Nios II Hardware] nios II download
I' m using the Quartus 9.1(SP2) and NIos 9.1 IDE. I wrote v files and C code for speech recognition system.V files were compiled correctly & also the nios IDE build the project.When I try to run the project and download it to the board, it displayed as follows.
Pausing target processor: OK
Reading System ID at address 0x000000D8: verified
Initializing CPU cache (if present)
OK
Downloading 02000000 ( 0%)
Downloading 02010000 (87%)
Downloaded 74KB in 1.2s (61.6KB/s)
Verifying 02000000 ( 0%)
Verifying 02010000 (87%)
Verified OK
Starting processor at address 0x020001C4
and displayed in the upper bar <terminated>nios Nios II Hardware configuration[ Nios II Hardware] nios II download
Can u help me regarding this......
Thank U...
1 Reply
    It seems everything is fine. What exacty is your problem? The software was correctly downloaded and the processor was started.
    If you are expecting a console, check that your SOPC system has a JTAG Uart compenent, and that the IDE is configured to launch a nios 2 terminal after the download.
