15 years ago<terminated>nios Nios II Hardware configuration[ Nios II Hardware] nios II download
I' m using the Quartus 9.1(SP2) and NIos 9.1 IDE. I wrote v files and C code for speech recognition system.V files were compiled correctly & also the nios IDE build the project.When I try to run the...
15 years agoIt seems everything is fine. What exacty is your problem? The software was correctly downloaded and the processor was started.
If you are expecting a console, check that your SOPC system has a JTAG Uart compenent, and that the IDE is configured to launch a nios 2 terminal after the download.
