16 years agoNIOS II top level in Quartus II
When compiling the source files generated by SoPC Builder in Quartus II, is it necessary to make a top-level entity? SoPC Builder generates a file called nios_system_name.v which I set as the top lev...
16 years ago --- Quote Start --- I didnt do any sort of connection with pins (if you're referring to bdf file). All I did was add all the verilog files from SoPC builder and pin assignment then compiled. Could you please elaborate on your method. --- Quote End --- Hi, when you look into your verilog file you will find inputs and outputs. I would expect at least a clock and a reset input. When you will run your design on a certain board you have to make proper pin assignments. Kind regards GPK
