17 years agoNios II to SRAM via Tri-State Bridge
Let's see how long it takes to get a 'good' answer to this question: :D Ok, I have a Nios II system (32-bit data width) connected to a single 16-bit SRAM through an Avalon Tri-State Bridge (th...
17 years agoJake is rigth, all you need to do is
open your sopc builder project chose menue FILE -> New component change to TAB Signals Button "Add Signal" rename the new Signal clk change its Interface to clock sink add more new signals like adr, data, nrd nwr... choose interface avalo_tristate_slave if your component has negative logik choose read_n otherwise read as signal type. if you add your data interface, choose width to 16 and direction to bidir. you should now have a minimum of clock, data,adr,nrd,nwr,ncs don't worry about the direction, it is from the components view so read is input (output from fpga) change Signal Type to clk change to Tab Interface Button ADD INTERFACE Change default type to "Avalon Memory Mapped Tristate Slave" Setup your Timing according to your device datasheet, you can enter nSec as SOPC will take care about that. now finish your component and feel free to use it be aware of that you should check your avalon tristate bridge after adding this component about the shared signals creating such a component is quit easy and done within a couple of minutes including reading datasheet ....
