16 years agoNios II software
Hi, I'm new to developing Altera fpga hardware & software designs. Does anyone know where can I find some literature regarding the direct use of hardware design by nios II software? Example> ...
16 years agoRead the part about conduits in the Avalon documentation. You can map a conduit in memory and write and read from it on the Nios side. On the other side, you will have to interpret the signals -- this is very clearly specified in the Avalon documentation. You can start with this module definition...
module conduit (// Slave interface
input csi_clock_clk,
input csi_clock_reset_n,
input avs_s1_address,
input avs_s1_read,
input avs_s1_write,
input avs_s1_writedata,
output avs_s1_readdata,
output avs_s1_waitrequest,
// Conduit
output coe_user_clk,
output coe_user_reset_n,
output coe_user_address,
output coe_user_read,
output coe_user_write,
output coe_user_writedata,
input coe_user_readdata,
input coe_user_waitrequest);
Please note that the csi, avs, and coe prefixes are needed there so that SOPC can easily interpret what your signals mean. You will need this snippet after you try to create a custom component in SOPC...
