14 years agoNios II Programmer
Hi all, I have problem during setting Nios II Flash programmer. The problems are "system ID hash" not found and "system timestamp" not found. what should i do to connect the "system ID hash" a...
14 years agoDear Daixiwen,
I checked at "Generated Files". It generate .pof file. However, i still get the same error. No new error appear. Error code: 3 for command: sof2flash --input="H:/altera/RnI_Fest/barcodesystem/scanner_time_limited.sof" --output="H:/altera/RnI_Fest/barcodesystem/software/barcode_bsp/flash/scanner_time_limited_epcs_flash_controller.flash" --epcs --verbose Thanks.
