16 years agoNIOS II flash programmer
Hi, I have build a custom board with EP3C16Q240 having M25P16 [Nymonix 16Mb] serial flash device to store my FPGA configuration data & Program data. After building the .sof and .elf when I tr...
16 years agoyour entry seems to be correct.
if you run the nios2-flash-programmer, does it print out that it is reading / using this file ? maybe you need to add the --debug oder --verbose option, see the help dialog what option it is i can't remember right out of my head. if you still get the same message, check your epcs <-> fpga connection. do you have the chance to verify with an altera epcs device ? just to see that everything else is correct and the source of this problem is related to your device and or the override file.
