16 years agoNIOS II flash programmer
Hi, I have build a custom board with EP3C16Q240 having M25P16 [Nymonix 16Mb] serial flash device to store my FPGA configuration data & Program data. After building the .sof and .elf when I tr...
16 years agoyou will need to create a text file that includes the missing informations.
<nios2_install>/bin/nios2-flash-override.txt and inside this file you include the informations like this example --- Quote Start --- [EPCS-010216]# EPCS64N (Spansion-lead-free) S25FL064A0LMFI001 sector_size = 65536 sector_count = 128 --- Quote End --- The Spansion datasheet for this device says Manufacture Identification 01h Memory Type 02h Memory Capacity 16h putting all these informations together delivers 010216 so you will need to look into the datasheet of your device and find the require informations and created the file. BTW: too bad that the nios forum has lost so many postings, there was a realy complete override file and i remember that epcs device was already listed ...
