16 years agoNios II Flash Programmer (error)
Hello, I've built an SOPC system with SOPC Builder, and I've written my code using Nios II IDE. i was using a DE1 board, i try to program my main program code into the Flash memory (EP...
16 years agothanks for the reply..
but in mine sopc, i didnt add the SRAM components..i did add a SDRAM.. and i pointed t he program memory, read only memory, read/write memory, heap memory, stack memory to SDRAM. can i do that so ? another question, if let said i had success to build a .txt file into the flash memory, how do i recall the .txt file out using NIOS II IDE ? what command have to wrote in the NIOS II IDE ?
