16 years agoNios II Flash Programmer (error)
Hello, I've built an SOPC system with SOPC Builder, and I've written my code using Nios II IDE. i was using a DE1 board, i try to program my main program code into the Flash memory (EP...
16 years agoTry doing this
reset address pointing to ->external Flash Exception address ->SRAM In the NIOS II IDE, in the system library property make the program memory, read only memory, read/write memory, heap memory, stack memory are pointed to sram and try.
