19 years agoNios II Eval kit 1c12 firefly
OK I have just started so sorry if this is covered elsewhere.
I have just opened the Nios II Eval kit I got last year. I figured it would be good to install quartus 7.1 at the same time. The install went fine. Quartus open the supplied Nios II Eval kit for 1c12 fine compiled and downloaded. When i open SOPC it ask to upgrade the project. On generation I get a lot of errors -about dangling Inputs at start up on the CLK lines for the components -and two components are missing *altera_avalon_asmi_classic 2.1 *altera_user_board_setup_classic 1.0 It appears in the upgrade from a 4.1 project the clock and otherthing have been screwed. I also tired the mircotronix project (1.3) I found on the net. with no luck Is there somewhere I can get a working project for the EP1c12324c8 firefly nios II eval kit? Does anyone have these components? You can email me files on: peter.hickey at scalecomponents.com Thanks Peter1 Reply
Did you get anything ?
i still have this kit too but only the schematics of the firefly but not for the board it is mounted on, so no chance to create my own project what would not be the problem Kind regards Michael
