11 years agoNios II EPCS booting problem
Hi, I am using DE0 nano and trying to boot Nios II from EPCS configuration device. I am following the procedure mentioned on this link (http://www.alterawiki.com/wiki/epcs_bootloaders). Th...
11 years ago --- Quote Start --- SOLVED. For EPCS default bootloader you need to use mem_init and most importantly EPCS controller's clock input should be < 25Mhz. --- Quote End --- I'm still having problems booting my Nios II from an EPCS16 device. I thought reducing the EPCS flash controller clock might fix it but no. I think the clock reduction is still needed so it has been reduced from 72MHz to 12MHz. The Nios II core still runs at 72MHz - could this be a problem? My system looks like this :- EPCS_flash_controller located at 0x00100000; Nios II reset vector set to 0x00100000. There is 64kB of on-chip memory starting at 0x01010000 and the Nios II exception vector is set to 0x01010020. The Nios II program runs correctly when using the debugger so the code's ok. I use these commands to generate the programming files sof2flash --epcs --input=C3D.sof --output=C3D.flash elf2flash --epcs --after=C3D.flash --input=C3D_comms.elf --output=C3D_comms.flash nios2-elf-objcopy –input-target srec –output-target ihex C3D_comms.flash C3D_comms.hex Next I use the Convert Programming File utility in Quartus II to combine the .sof and .hex into a .pof. The map file created looks ok with the .hex file starting from the next address after the end of the .sof. Looks like this BLOCK START ADDRESS END ADDRESS Page_0 0x00000000 0x00122F6B C3D_comms.hex 0x00122F6C 0x00126E8B Then I program the EPCS but when I try to run the program it fails. Any help much appreciated.
