15 years ago
nios ii assembly language programming
hello
please can anyone tell me if there exist a way ( a software :D )to compile and execute nios ii assembly language programs but without having the DE2 board because i'm learning the assembly language of the nios ii but i don't have access for the board and for practice i need to try and execute some programs..
thank you ;)
    thank you kevin for this quick answer :)
    i'll try to look for tutorials concerning the nios ii ide because i'm new to it in order to find how to use the nios ii ISS directly ...
    please if u know a good link that'll help me let me know
    thank you very much ;)
    The ISS does not require target hardware. As far as I know it is not available as a separate download separate from the rest of Nios II EDS. It is one of the available options when managing debug configuration is Nios II IDE.
    thank you Kevin for your answer:) but i'm wondering :confused: if this nios II instruction set simulator exits as a free software by itself ....because i know it is included in the nios ide which requires target hardware but alone i don't know ??
    thanks for any help:)
    Altera has a Nios II Instruction Set Simulator (ISS), although I don't think it is officially supported anymore. I only ever tried to use it once briefly, so I don't know much about it. If you do a search for it, you can probably find more info. You can also run "nios2-iss --help" in the Nios console for some info.
