9 years ago
Nios II and Python
I am trying to send char bytes from my fpga to a python program, the data bytes are hexadecimal data, and those values will be plotted in a GUI table. The nios code is
unsigned char temp =0xa;
unsigned char temp1 =0xb;
unsigned char temp2 =0xc;
while(1)
sendFloat(temp);
sendFloat(temp1);
sendFloat(temp2);
return0;
void sendFloat( unsigned char n)
char number[20];
int i=0;
snprintf(number, sizeof(number),"%u", n);
while(i<20){
IOWR_ALTERA_AVALON_UART_TXDATA(UART_BASE,number[i]);
delay();
i++;
IOWR_ALTERA_AVALON_UART_TXDATA(UART_BASE,'\n');}
The Python code is
import serial
ser= serial.Serial('COM5',baudrate =115200, timeout=1)
while 1:
fpgadata=ser.readline()
print(fpgadata)
    Thanks for your reply, actually i forgot to mention the problem there was also some random garbage values were printed with actual data.
    But i got the solution for my problem, the char number[20] should be number[2]
    Your Nios code doesn't show whether you setup your Baudrate correctly - or at all. (Depending on your FPGA design you may not need to. However, it will need setting up somewhere.)
    Refer to chapter 7 - UART Core - of the "embedded peripherals ip user guide (https://www.altera.com/en_us/pdfs/literature/ug/ug_embedded_ip.pdf)". This has some code you can crib from too.
    Python looks adequate. Lookup the "Serial.inWaiting()". I think you'll find it helpful.
    Cheers,
    Alex
