SK_VA
5 years agoNIOS II 20.1 Command Shell Crashing
Recently I installed Quartus 20.1 in my system. Even though the GUI is working properly, the command shell crashes always. When I try to open Command shell a black screen blinks and goes off.
EricMunYew_C_Intel
5 years agoHi, Sanju
Can you follow below to re-install again:
1. install WSL for windows
i. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/nios2/n2sw_nii5v2gen2.pdf (chapter 2.1)
Note: Windows 10 build version 16215.0 or higher is the recommended operating system version.
ii. After installation has successfully completed, launch Ubuntu 18.04.
iii. Install additional distro packages required for Nios II EDS using the following commands:
a. sudo apt-get update
b. sudo apt install wsl
c. sudo apt install dos2unix
d. sudo apt install make
2. install nios2 eclipse folder
Eric
