15 years agoNIOS 2 SPI as SLAVE
Hi, I want to implement a nios 2 softcore with an spi slave. All SPI examples I have found implement the spi as a master and the documentation is not very specific about configuring a slave dev...
15 years agoYou are correct with your assumption.
The FPGA will be part of a device that performs specific tasks and will be remotely controlled via SPI form a different device. So we implemented a SPI interface with the new Qsys and configured it to behave as a SPI Slave device. I have taken a look in the guide before but I am afraid I need more guidance. My specific Problem is this: The FPGA will receive a Command String from another device telling it what to do. I need to understand how I can activate the SPI interrupt in C, so that everytime a transmission is started the interrupt handler can do what I need it to do. I believe I need to register the interrupt or something and define the handler. SO far I tried this: Initialising:void init_spi{
/* Enable SPI read-ready interrupt */
alt_irq_register(SPI_0_IRQ, (void*) &spi_context, handler_spi_isr);
} handler: static void slave_spi_isr(void* context, alt_u32 id)
printf("Works, yay!\n");
} I put that in the Hello_World example and it compiles okay. But an spi command send to the fpga does not trigger the handler. What's weird though, when I did the same inside the NIOS 2 Debugging enviroment, there was an error message telling me "target faild to interrupt". I am sorry, if my questions or my confusion seems stupid, but I am more used to 8-bit architectures, where I can look up the internal register structure of a given processors hardware and where I know every Register by heart.
