15 years agoNIOS 2 SPI as SLAVE
Hi, I want to implement a nios 2 softcore with an spi slave. All SPI examples I have found implement the spi as a master and the documentation is not very specific about configuring a slave dev...
15 years agoCan you be a little more specific in your definition of what you want regarding master and slave.
The NIOS II is a processor, and it is a master on the Avalon-MM bus. The NIOS II can have an SPI peripheral in its memory map. That peripheral will be an Avalon-MM slave. The peripheral could be an SPI master or slave, depending on the implementation. There is also an SPI-to-Avalon-MM bridge that you can use to have an SPI slave that allows you to control an Avalon bus as a master. Confusing, eh! --- Quote Start --- I want to implement a nios 2 softcore with an spi slave --- Quote End --- I suspect that what you want is an Avalon component that implements an SPI slave. That component would also be an Avalon-MM slave. Take a look in the Embedded IP Peripherals users guide. http://www.altera.com/literature/ug/ug_embedded_ip.pdf p85: "The SPI core can implement either the master or slave protocol". Cheers, Dave
