14 years ago:nIO_PULLUP(PIN:AK3)AND PORSEL(PIN:AL2) are floating
dear all:
Very pleased to be able to get your help, my useing device is EP2S180, and now my JTAG chain cannot access. and i check my schematic found that THE PIN :nIO_PULLUP(PIN:AK3)AND PORSEL(PIN:AL2) are floating , my question is: is it becasuse these two floating pin make the JTAG chain unable to be accesed. (Normal power supply,)2 Replies
thank you..
--- Quote Start --- and now my JTAG chain cannot access. and i check my schematic found that THE PIN :nIO_PULLUP(PIN:AK3)AND PORSEL(PIN:AL2) are floating , my question is: is it becasuse these two floating pin make the JTAG chain unable to be accesed. (Normal power supply,) --- Quote End --- No. That should be fine. Per http://www.altera.com/support/kdb/solutions/rd02232004_2958.html "nIO_PULLUP, PORSEL, and VCCSEL pins ...[have]... internal 2.5kohm pull-down resistors always active on these pins" Cheers. Dave
