18 years agonichestack TCP_IP for Nios II
Hi
I have a stratix II EP2S60, i want to use nichestack TCP/IP for communication, i have a simple problem: the connection to board is good, i use simple soket server for starting, with telnet i would not send 0,1, 2, but i would send for example 0xA0, 0xA1...., i can't even if i modifie the code "simple_soket_server.h": # define CMD_LEDS_BIT_0_TOGGLE '0' by # define CMD_LEDS_BIT_0_TOGGLE 0xA0 it sends 0 then x then A then 0 instead of 0xA0 once for all with telnet thanks2 Replies
No link with above posts, NicheStack for Nios II seen in http://www.altera.com/products/ip/processors/nios2/tools/embed-partners/ni2-network-stack.html#niche_stack is a version of InterNiche’s NicheStack IPv4 network stack optimized for the Nios II architecture. What does it really include ? Can it be used in any commercial products with no royalties ? Can it be used without ucOS II ? Because it is not suitable for low cost and very simple ethernet client commercial products. Thanks - Altera_Forum
must modify you c programm to receive multi character in a buffer,and convert them to binary value.
