16 years agonewbie question on FPGA/CPLD's
I'm just learning how to program a MAX II device. The device has pins that are meant to be driven by a clock. I assume that that having dedicated clock pins makes implementing timing across logic u...
16 years agoTo answer the second question first, yes it's ns scale, comparable with e.g. HC or AHC logic. Consult the datasheet or perform a Quartus timing simulation to see the exact logic delays.
Clocked logic behaves similar as if built from discrete flip-flop logic devices. As far as the logic response has to travel one ore more flip-flop stages, it will be of course slowed-down with a slower clock. That's usually, what a clocked logic would be expected. You always get exactly the programmed behaviour, also in terms of clock cycles.
