10 years agonewbie question: how to run emulator
I installed Altera SDK on my system without any FPGA board. I want to try the sw before ordering the hw. I build a fft1d example. I used the makefile which gives error when I run: Query for n...
10 years ago[INCORRECT]The end of the compilation tells you how to do this. If you don't specify a board the emulator will run, but I don't know if it can run as you want. Have you tried? Also, for the next time, this post should be in the OpenCL part of the forum.[INCORRECT]
I am sory to say the previously mentioned information is incorrect, I forgot that when you do not specify a board a default one is chosen. I did a quick test to answer your question and I thought it worked. So again I am sorry.
