18 years agoNewbie Help Request CPLD MAXII
Hi all. I want to build a digital clock, with several 7 segments displays (HH:mm:ss). How can i make the 1s clock to drive my 4bits counters? My board has a 50Mhz clock. How can i make 1s pre...
18 years agoThe best thing you can do is to just keep practicing. However, I (and I'm sure others) can suggest a little reading material:
VerilogHDL by Palnitkar is great as a reference book. http://www.amazon.com/verilog-hdl-2nd-samir-palnitkar/dp/0130449113/ref=sr_1_1?ie=utf8&s=books&qid=1222294327&sr=1-1 and Altera recommended coding practices: http://www.altera.com/literature/hb/qts/qts_qii51007.pdf?gsa_pos=1&wt.oss_r=1&wt.oss=coding%20practices If you would consider a course. Sunburst Design teaches some good ones: http://www.sunburst-design.com/ Jake
