18 years agoNewbie Help Request CPLD MAXII
Hi all. I want to build a digital clock, with several 7 segments displays (HH:mm:ss). How can i make the 1s clock to drive my 4bits counters? My board has a 50Mhz clock. How can i make 1s pre...
18 years agoAnyway, you could write your own divider by 50,000,000 as an exercise. Try to write it in Verilog to start with an HDL language. The frequency accuracy in ppm will be the same as the one guaranteed by your crystal oscillator.
You can use the Quartus II templates to start learning. Once you have created your .v file go to Edit>Insert Template and browse the available templates. Cheers OD
