16 years agoNew to VHDL: Understanding timer.vhd implementation
I'm an old hand at C/C++ just getting my feet wet with VHDL. In the course of my learning, I've used the SOPC builder to create a simplified system that included a timer. Part of the emitted VHDL c...
15 years agoThanks for the response. I've got a follow-up question regarding the timer.vhd implementation.
There is some code driven by an internal signal named "clk_en". At the beginning of the architecture, there's this:
clk_en <= std_logic'('1');
And then later on there's this:
process (clk, reset_n)
begin
if reset_n = '0' then
force_reload <= std_logic'('0');
elsif clk'event and clk = '1' then
if std_logic'(clk_en) = '1' then
force_reload <= period_h_wr_strobe OR period_l_wr_strobe;
end if;
end if;
end process;
What is the purpose of checking clk_en? I'm guessing it's primarily for simulation purposes as a guard in the event that there is an immediate rising edge to prevent (in this case) force_reload from being updated with data that may not yet have a defined value. Is this the case? Thanks, --tim
