16 years agoNetlist writer
Hi I am using the SOPC builder to create a NIOS based system. I wanted to use an open source tool minSSTA to perform timing analysis. The tool accepts .bench: circuit netlist file - Here is...
16 years ago --- Quote Start --- Thanks for you quick response I am able to generate the .vo file, does this mean that I have the licence for the files. Can I make quartus synthesize the nios2 ip to a simple library instead of fpga primitives. Or is there any eda tool which can take the output from altera synthesis and synthesize the ip into a simpler library of gates. Are the modules provided in eda/sim_lib/stratixiii_atoms.v synthesizabe or are they just functional models which can be used in Model Sim --- Quote End --- Hi, as far as I know they are only usable for functional simulation. Kind regards GPK
