16 years agoNetlist writer
Hi I am using the SOPC builder to create a NIOS based system. I wanted to use an open source tool minSSTA to perform timing analysis. The tool accepts .bench: circuit netlist file - Here is...
16 years ago --- Quote Start --- Hi I am using a Nios 2 CPU, will the generated .vo netlist contain primitives describing the CPU as well as it is encrypted. --- Quote End --- Hi, when you use a time limited NIOS version you could not write out a <>.vo file. Kind regards GPK
