14 years agoNegative hold time
Hi i started reading a data sheet and found the external device setup/hold time specified the specified setup time is positive but the holds time is specified as negative after the...
14 years agosetup/hold time is always stated as positive with respect to register. But when viewed from pins (and that is practically what you handle) then it go shift such that either can be positive or negative. The shift of timing window is due to delay differences of clock and data within device from register to its pins.
