12 years agoNeed some quick advice and direction on FPGA uses for quadcopters
My Altera Cyclone IV has been an awesome education board. However, every-time power is shut off I lose my program. I was just curious if their are any FPGA's out there that don't lose their program w...
12 years agoWhat u're doing to erase it is powering off the circuit. This kits have a USB-Blaster programmer built-in the board. From Quartus, when you start the programmer windows, it appears in the right top corner the "mode" of programming. Probably u selected "JTAG" mode. In this mode you lost the configuration when you power off the circuit.
Try to select "Active Serial". A pop-up window tell you that the programming file extension ( .sof ) isn't compatible with JTAG mode. Click Ok and the Add a programming file. Select the one with .pof extension. Programm again. The configuration will be stored in the EPCS memory.
