13 years agoNeed some advice about selection of FPGA devices(probably with PCIe interface)
Hi everyone, I am a PhD researcher in university and recently my advisor wants to start a project regarding using FPGA to process some data from chemistry sensors. We have a lot of NEEKs (nio...
13 years agoI see. Thanks:)
--- Quote Start --- Interfacing your system to a cell phone is simple. You just use network programming. In which case, what is wrong with talking directly to a NEEK? If you need more processing power than the NEEK can provide, then your FPGA hardware will always need to reside in a box (big FPGAs need proper cooling). If that box needs to be moved around, then the MaxExpansion cube and a laptop is a good solution. If not, a PCIe card in a desktop is fine. You're starting by asking the *wrong* question, i.e., "What board?". The question you first need to answer is "What processing?" If your algorithms require lots of floating-point performance, then you will need to look at a high-end device, i.e., Stratix V. However, if your processing can be implemented using fixed-point math, then the Cyclone or Arria or earlier Stratix series devices would be ok. Cheers, Dave --- Quote End ---
