13 years agoNeed some advice about selection of FPGA devices(probably with PCIe interface)
Hi everyone, I am a PhD researcher in university and recently my advisor wants to start a project regarding using FPGA to process some data from chemistry sensors. We have a lot of NEEKs (nio...
13 years agoHi Dave,
Thanks for your reply:> Mobile means cell phone. I have checked the two links you gave.They would be helpful. So if I am on a desktop with a FPGA board with PCIe interface, I think I can just directly insert it to the PCIe slot on the motherboard,right? I understand I should not just buy a board without considering the resources I need to use. However, the only FPGA devices I have used is NEEK as I mentioned. So right now I just need some general suggestion on what devices are available there and what are popular(Altera , Xilinx or others are all OK).... I will just use them as a start point and start to do my work... Now I just feel lost... Yes. I know University program of Altera. Actually I contacted them once before probably two years ago:> --- Quote Start --- What do you consider mobile? Your laptop or your cell phone? :) If your laptop has an "ExpressCard" slot, then you effectively have a PCIe connector on the side of your laptop. You can use this to connect to a box that contains standard PCIe cards, eg., the MaxExpansion cube or the OneStopSystems micro-ATX motherboard (these two places are the same company) http://www.maxexpansion.com/ http://www.onestopsystems.com/ As to which FPGA board to use. Don't buy anything until you have created some example designs. Assume you have purchased one of the above boards; create a design for it. What are the resource requirements? Is the board sufficient? Buy a board only after you have analyzed what you need to use it for. You have to create the HDL at some point, so start now. Also contact the University Program. They may be willing to donate a board, eg., an older Stratix IV rather than a new Stratix V board. Free is good, right? :) Cheers, Dave --- Quote End ---
