HK15's avatar
HK15
2 years ago
Need ODC, POPs and Material Declaration data
Need ODC, POPs and Material Declaration data for EPCQ4ASI8N
  • NazrulNaim_Intel's avatar
    NazrulNaim_Intel
    Nazrul Naim
    NazrulNaim_Intel
    Sorry for the delay. For information needed as requested, it can be accessed through the link below.
    Link : https://cdrdv2.intel.com/v1/dl/getContent/693190?fileName=EPCQ4ASI8N_20191201100637_v1.xml
    Below is the step how to open XML file in Excel
    1. Open a new blank Excel file
    2. Click on Developer tab, then click Import
    3. Select the xml file you want to import, then click Import
    4. Click "OK" on pop-op information, and also "OK" on where to Import data
    5. The table will then be generated, and you will see a lot of "blank" cells due to the long text of the "legalDef" column AK.
    6. I recommend to delete column AK so that the other columns will display better:
    Hope that helps.
    Nazrul Naim
