alperenpalp
5 years agoNeed Help with FIR II TDM.
I've been trying to get FIR filter working for quite a while, but I've been runnig into problems.
I am basically trying to implement 51 tap low-pass filter. I am also trying to save hardwa...
CheepinC_altera
5 years agoHi,
Sorry for confusion. Just would like to check with you what is your clock rate and input sample rate? From the screenshot, seems like the sink_valid is held at constant 1. This would imply input sample rate = clock rate. Please let me know if there is any concern. Thank you.
alperenpalp
5 years agoClock rate is 60 MHz and the input rate 15 MSPS.
Should I toggle the sink_valid signal at input sample rate?
