10 years agoNeed help with a VIP design like the C5G example
Hi Guys, I put together simple LPDDR2+vip_vfr+vip_cpr+vip_itc system based on the C5G example for the StarterKit board. To keep the system simple I removed a number of IPs. Instead of th...
10 years agoHi Guys,
I've attached more screen shots of my system. I added the LPDDR2, Sequences, a PLL to provide 120Mhz local IP clock. As before, I can R/W from all IPs but not from the new LPDDR2. I followed the C5G example with all pin constraints, etc. The Clocked Video controller has its own 44.8Mhz from outside qsys. Could someone look at my configuration and tell me if there is something wrong? Thanks, S.
