10 years agoNeed help with a VIP design like the C5G example
Hi Guys, I put together simple LPDDR2+vip_vfr+vip_cpr+vip_itc system based on the C5G example for the StarterKit board. To keep the system simple I removed a number of IPs. Instead of th...
10 years agoThanks Taz1984! Yes, the 970x720 is the display panel requirement.
The Frame-Reader is connected directly to the ONCHIP RAM which is way too small for what we need but for now its is easier to debug. Here are some more details: -When the Frame-reader is turned ON I do get video (blue screen) -In simulation I can see the FR master read from RAM but JUST once the data that I wrote there and then stops. -I do not have a Sequencer in the path between the FR and the ITC could that be the problem? -Could the fact that my RAM is too small be the problem? why would the FR do just one access to RAM and stop? -Could you provide a simple example of configuration of a FR in HW and configuration in SW? -What about the bus widths of the RAM, Frame-Reader, Sequencer and itc? should they all be say 32b and should they match? Thanks, S.
