10 years agoNeed help with a VIP design like the C5G example
Hi Guys, I put together simple LPDDR2+vip_vfr+vip_cpr+vip_itc system based on the C5G example for the StarterKit board. To keep the system simple I removed a number of IPs. Instead of th...
10 years agoDo you have the correct timings including Vsync, hsync and blanking for your Output-Video-Setting? Why 970x720? This is not a standard format, is it?
Where is your Frame Reader connected? On-Chip-RAM? Could you please add pictures in higher resolution of the QSYS-System and the configuration? It hard to read them... The ColorPlaneSequencer is there to put either the from serial color-plane-transmission to parallel or reversed...
