16 years agoNeed help! Weird CycloneII LED assignment problem!
Hey guys, My pins on board don't work as what they should do according to pin assignment. In my design entity, I have outputs LEDR0, LEDR1... LEDR5. I assigned them to correct LED pins, no...
16 years agoWhat's your device option for unused pins? It may be e.g. "output drinving ground". Apart from changing this option to "tristate with pull-up" you should generally define unused but connected pins in your design top and asign correct pins to them. It's meaningful in my opinion to have them ready for later use.
